Error Code 2014 T/A
Eddie Spaghetti
Just coming home tonight and my CEL lit for the very first time on my '14 T/A...
The error code read P000B: Bank 1 Camshaft 2 Position Slow Response.
Before I go and strangle the dealer since the car has under 1500 miles, I'd appreciate some input if anyone out there has seen this before.
Jack B
NE Ohio
If you do a little research you will see your code or a similar code has shown up when some of the cars have an oil pressure issue. That is a worse case scenario, it could be a multitude of lesser issues. The oil pressure is the worst case. As an example, there was a car with a bad oil pressure transducer.
Tombala
