1996 GTS fronts: 315/30's on 18x10 rims?
Tom and Vipers
Jeannette, PA 15644
Looks like only possible options for Rival-S's with a larger front - and they would have the same diameter as the stock 275/35's.
If 18x11's, I thinking definitely yes.
Toyo r888's 295/30's would just barely be OK with 18x10's.
Thinking the Rival-S will last longer than the r888 and be actually cheaper per mile.
NOTE: TireRack said the Rival-S does not heat cycle while the r888 does. So that would be a big advantage if true.
Viper123456
