Have anybody used partsrack to buy 3.55 gears from them?
Ccorde
Hi guys. Shopping for 3.55 gear set for my 2009 Vert right now. And need to know if any of you has any expiriance with partsrack and how is a quality. Any noise from a diff after install?
TalonTSi90
Cant speak for the actual part, but im sure i can say the unanimous verdict is you can trust JonB.
Kirkinsb
I do. Bought them from him over a year ago. Has everything you need in the kit, JonB is top notch. Helped me find a front 6-spoke wheel just recently. Probably one of the most Viper Knowledgeable guys out there. My gears are great with no noise at all. Just make sure you put the right friction modifier in your fluid when done. I had a speed shop put my 3.55s in since installation and tolerances of the gear is critical. JonB at Partsrack would get my money if I had to do it again.
cowger
Ditto -- got a set from him years ago and they've held up no problem. I did a write-up on the whole process, in case you're interested.
Bryan
stevensonjr
Yes, get all the fluids too. I bought the 3:55 and the carrier, spider gears etc. had chunks of metal in the rearend due to over use by the previous owner. Jon found a rebuilt unit and shipped it in 2 days. Good experience with Jon.
Javadog62
