Thread: 2004 Rebuild Question
Reply to Thread
Results 1 to 7 of 7
  1. #1
    Lightbulb 2004 Rebuild Question
    My name is Jeremy and I am new to this forum.
    I recently dropped a valve in cylinder 8 and destroyed the heads as a result. My mechanic (in las vegas) recommends I replace all sorts of parts in the process, and I would really appreciate any feedback on what you all would do if your budget was $15k to fix/upgrade this damage. 2004 SRT Roadster
    Thank you in advance for any information
  2. #2
    Northeast
    NE Director at Large
    ViperJohn's Avatar
    Join Date
    May 2003
    Maryland
    Default Re: 2004 Rebuild Question
    Well, where do you want to go with your engine build? What performance goals did you have in mind?
  3. #3
    the best i can for $12-15k
    this car is an everyday driver. I don't track it, and I don't mind it being loud. I have Belanger building headers with straight pipes now. I am unprepared and inexperienced at this level of work but i am being forced into this with the damage. Any parts/mechanics you can recommend would help me out tremendously.
  4. #4
    UT/AZ
    Join Date
    Oct 1995
    Not sure of prices in Vegas, but in NJ in my old shop, if you dropped a valve, to bring the motor back to stock New condition kiss 12k-15k good by. O yea all most forgot, it will be bigger than stock how much depends how bad the cylinder was gouged and how much they have to bore it out, new liners and pistons, lots of fun stuff, it adds up fast in a aluminum V10 with pressed liners.
  5. #5
    thx Steve.
    I have a mechanic out here that told me for $12k in parts he would get the heads redone and bigger (idk how much), cam with a 623 lift, springs/valves/rockers, 40:60 pistons flat top, H rods, hiflow heads, modified crank shaft, and about $3500 in labor? Additionally, he recommends a stage 3 4puck clutch.
    How does this sound and what should I watch out for or be aware of? Thank you
  6. #6
    UT/AZ
    Join Date
    Oct 1995
    Sounds good, since you are going that far with it, Install a T&D rocker arm kit its the best on the market very stabile, 10 times better than the stock stamped rockers. Good luck with everything. If they make it for your gen Viper, I know they make it for the gen 2 thats what I have.
  7. #7
    ill let my mechanic know. ty steve
  1. viper engine for sale 2004 needs a rebuild
    By loudviper in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 11-10-2012, 11:34 AM
  2. Arrrow Rebuild Question?
    By SneakyPete in forum RT/10 and GTS Discussions
    Last Post: 09-02-2003, 03:16 PM
  3. Problem with Arrow Rebuild & Question
    By GATOR SERPENT in forum RT/10 and GTS Discussions
    Last Post: 05-21-2002, 07:55 AM
  4. Arrow rebuild - Question
    By 94 RT/10 Black MAMBA in forum RT/10 and GTS Discussions
    Last Post: 11-06-2001, 06:56 AM
  5. Arrow rebuild question/problem
    By Jim Sullivan in forum Archive Management
    Last Post: 07-09-2001, 02:27 PM
Tags for this Thread
View Tag Cloud
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
