A/C Condenser
jmyke
1998 RT/10 with 27,000 miles, any ideas why condenser is cracking at the front lower left corner where fitting attaches? This will be the 4th one the dealer installed, they last anywhere from a month to 9 months but eventually they crack, coolant loss and replacement needed
steve e
Something must be flexing more than it should, was the frame recall done. Do the attachments have the right support cushions. Is it the same Mechanic doing the job, had my Dodge truck in John Johnson Dodge 4 times for warrenty work for the same problem, went to a different Dealer and everything is good.
J
jmyke
the frame recall was done in 2005 but I havn't been able to find any info on supports or pads or anything for condensed support, if it happens again I will see if there is any play in the condenser before the mech. takes it out
Thanks for the info
Liberty235
