Thread: 1995 Viper Corroded Brake Booster
Reply to Thread
Results 1 to 5 of 5
  1. #1
    Join Date
    Jun 2017
    Franklin, Ma.
    Default 1995 Viper Corroded Brake Booster
    Hello I am making an offer on a 1995 Viper tomorrow and noticed that the brake booster is a little corroded. Not sure if this is a typical problem with these cars or something I should be more concerned about. I am planning on just replacing it but is there anything else this could impact that I should also check.
  2. #2
    Northeast
    NE Zone Director
    ViperJohn's Avatar
    Join Date
    May 2003
    Maryland
    Default Re: 1995 Viper Corroded Brake Booster
    No, I'd be more concerned about the loose connectors in your picture.
  3. #3
    Join Date
    Jun 2017
    Franklin, Ma.
    The loose connections were from the guy trying to get the car going since the battery died and so the alarm wouldn't allow him to start the car again. He was trying to charge the battery from the front. The car is running fine now and the brakes work fine too. I have not seen others with a corroded brake booster before is this common have you seen this happen before?
  4. #4
    Join Date
    Aug 2005
    Chandler AZ
    Quote Originally Posted by pieceofchum View Post
    Not common from the standpoint of people mentioning it on the forums. I can not recall anyone saying anything about it. My best guess is that the brake reservoir cap fell off and brake fluid blew back onto the booster. Brake fluid will remove paint, and then the metal corrodes if not treated. Just a guess, though.
  5. #5
    Quote Originally Posted by AZTVR View Post
    I was originally thinking stored in rain, or somewhere moist? But spilled brake fluid makes sense, that is nasty stuff and can damage finishes.
    -Travis
    getupandgo.blog
  1. Replacing corroded brake lines, options?
    By BW96snake in forum RT/10 and GTS Discussions
    Last Post: 02-01-2011, 12:08 AM
  2. Brake booster
    By rpm9000 in forum RT/10 and GTS Discussions
    Last Post: 06-16-2010, 09:47 AM
  3. Paint on brake booster- 01 GTS
    By martyb in forum RT/10 and GTS Discussions
    Last Post: 08-17-2009, 01:34 PM
  4. Brake Booster Problem?
    By Xhlr8n in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 03-26-2007, 02:07 PM
  5. Brake fluid leaking out of power booster!
    By 94 RT/10 Black MAMBA in forum RT/10 and GTS Discussions
    Last Post: 07-28-2004, 09:40 AM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
