Thread: 2006 with 17K miles won't go into reverse
Reply to Thread
Results 1 to 8 of 8
  1. #1
    Midsouth
    nodoor's Avatar
    Join Date
    May 2009
    Default 2006 with 17K miles won't go into reverse
    I recently had a performance shop replace the original exhaust with straight pipes. I've driven the car 10 times with no issues since then. Yesterday and today when I start the car it won't go into reverse. Running, off, hill, flat doesn't matter. All other gears are fine. Shifter won't even go into the slot as if it is not there. No warning lights and no error codes. Any help or suggestions appreciated.
    Its better to burn out than fade away - Def Leppard
  2. #2
    Great Lakes
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    Default Re: 2006 with 17K miles won't go into reverse
    Have you checked reverse lockout fuse, plug to solenoid ?
    I don't do "PM's" and I NEVER read "visitor messages" since I prefer DIRECT communication.
  3. #3
    Midsouth
    nodoor's Avatar
    Join Date
    May 2009
    I have not. Is there something on the forums to show me how to do that? Thanks
  4. #4
    Join Date
    Aug 2005
    Chandler AZ
    Quote Originally Posted by nodoor View Post
    I would check the fuse first and then the connector at the solenoid and also the connector on the harness (C300 in picture) since either could possibly have been hit when they were messing with the exhaust.
  5. #5
    Join Date
    Aug 2005
    Chandler AZ
    I just checked. I think that it is a 15amp fuse in #14 slot & labeled maybe something like "Rear 02 Sensor to Heater Relay". Reverse lock-out and ship shift solenoids are also tied into that circuit.
    If that were the cause I think that you would have engine codes, though.
  6. #6
    Join Date
    Feb 2002
    Buffalo NY, USA
    Rear O2 wiring is damaged, very common on Gen-3 Belanger setups due to the sensor placement. Lockout and skipshift are powered off the same circuit.
  7. #7
    Midsouth
    nodoor's Avatar
    Join Date
    May 2009
    Quote Originally Posted by Viper Specialty View Post
    So if the wiring is replaced it will fix it? It was indeed a Belanger exhaust upgrade.
  8. #8
    Join Date
    Feb 2002
    Buffalo NY, USA
    No. The problem will just re-occur. We change the entire setup around to combat this. Downstream O2 sims are the easiest solution in your case if you dont have OBD2 inspections in your area.
  1. Replies: 0
    Last Post: 05-25-2012, 08:44 PM
  2. 2006 with 66,000 miles for $35k?
    By 3520henri in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 03-11-2010, 05:02 PM
  3. 2006 B/W with only 695 miles
    By drviperdds in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 11-30-2008, 07:58 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
