Thread: Clutch problem, please advise.
Reply to Thread
Results 1 to 10 of 10
  1. #1
    Join Date
    Aug 2013
    Default Clutch problem, please advise.
    My clutch took a dump on me this morning. Was damn lucky to get it into a empty parking lot before it went out completely. Good news was that I got it towed back to my house, without a scratch, for $75 bucks!....plus a very nice tip. Anyway, what would be a good clutch for a Gen2 Roe supercharged set up and what can I expect to pay for install? Thanks in advance.
  2. #2
    Great Lakes
    Steve-Indy's Avatar
    Join Date
    Oct 2000
    Default Re: Clutch problem, please advise.
    Shot slave cylinder? Is fluid level low? Boiled fluid in poorly shielded clutch hydraulic line?
    I don't do "PM's" and I NEVER read "visitor messages" since I prefer DIRECT communication.
  3. #3
    Join Date
    Aug 2013
    Quote Originally Posted by Steve-Indy View Post
    Thanks for the reply Steve. I don't know what it is yet and I don't have a lift at the moment to take a good look. The clutch pedal is super loose and effortlessly goes all the way to the floorboard and you can't put it into any gear. Last night, I drove to get gas and noticed it was a bit stiff rowing the gears. I smelled something fishy while I was pumping the gas, but it was hard to distinguish as there were so many other vehicles around including diesels. No smell when I got home. This morning, after about 10 minutes of driving, I knew something was wrong and soon after, it got to the point where I had to turn off the car to get into first and it would still creep forward with the clutch pushed all the way down.
  4. #4
    Join Date
    Aug 2013
    Oh, and brake fluid levels look normal.
  5. #5
    Join Date
    Jun 2003
    ALL OVER
    Age
    49
    buy a LUK off of ebay. its the stock clutch which is fine for the power you are at unless you do a bunch of drag racing from a dig.
  6. #6
    Join Date
    Aug 2013
    Quote Originally Posted by plumcrazy View Post
    Thanks Phil. I'll probably upgrade the clutch a bit from stock. After reading some threads, I may wind up replacing a bunch of $hit while this is all being done as I plan on keeping the car until I die.
  7. #7
    UT/AZ
    Join Date
    Oct 1995
    You did check the clutch master fluid level, sounds like the Clutch Master or slave cylinder is bad.
  8. #8
    Join Date
    Aug 2005
    Chandler AZ
    I went with something other than stock, at someone's recommendation. I did not like where the clutch engagement point was with the aftermarket parts. I did get used to it, though. This is one of the "risks" of going away from stock clutch/flywheel parts to consider.
  9. #9
    Join Date
    Aug 2013
    Pretty sure it's the slave cylinder. I've got a new one along with a 21 pound flywheel heading my way. Gonna stick with the stock clutch if at all possible as I won't be tracking or doing anything more than the occasional burn out.
  10. #10
    Join Date
    Aug 2013
    I know everybody already knows this, but John B at Viper Parts Rack is an incredible asset to any Viper owner. All you need is his phone number for any issue you ever have. Keith Laxson, who lives about ten minutes from me, will be doing the work.
  1. Any advise on changing the clutch pedal bushings on a 95 Rt.
    By vipurrman in forum RT/10 and GTS Discussions
    Last Post: 06-11-2011, 09:56 PM
  2. Help - New owner and first problem with car - advise please
    By Kmrumedy in forum RT/10 and GTS Discussions
    Last Post: 09-07-2007, 02:55 PM
  3. CLUTCH NOISE - NEED ADVISE
    By SRTTOM in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 08-14-2006, 01:51 PM
  4. Clutch & Flywheel Damage - Need Advise
    Last Post: 07-06-2006, 04:29 PM
  5. Clutch slipping or wheelspin? I need advise from the dragmeisters...
    By jwwiii in forum SRT10 and SRT10 Coupe Discussions
    Last Post: 03-24-2003, 02:14 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
