Go Back   Viper Club of America Discussion Forums > Racing and Performance Modifications > Viper Racing/Dyno Results/Time Slips > Time Slips
Time Slips Post your 1/4 mile time slips here!
Sponsored by: DragTimes.com
Old 08-03-2008, 07:42 AM   #1
anaconda666
Default Are my gears hurting me?
Went to the track yesterday. Car is a 1998 GTS with approx 575 hp at motor, has some motor work done, have not figured out all that it has yet , but here is some info - exhaust, smooth tubes, T&D 1.7 rockers, throttle bodies, lightweight flywheel, 3.73 gears. Best I could do is 12.23 @ 117mph. Are my gears hurting my time? What gears would be better? Stock? Thanks, Ron.
anaconda666 is offline   Reply With Quote
Old 08-03-2008, 07:47 AM   #2
uvbnbit
VCA President AL/TN
uvbnbit's Avatar
Default Re: Are my gears hurting me?
Not a bad 60 ft. Are you having to shift into 5th??
VCA Regional President
'98 Silver RT/10
Bone Stock (from the factory)
uvbnbit is offline   Reply With Quote
Old 08-03-2008, 12:32 PM   #3
anaconda666
No I only had to go to 4th gear. I have Kuhmo V700 tires and they are hooking up. I have an AEM computer that may need some more tweaking. Ron.
Old 08-03-2008, 02:52 PM   #4
MKB96Viper
MKB96Viper's Avatar
ANACONDA666,
There is something strange going on with that kind of power and 60' times. A 98 should easily run 11's with that much power, mods, and decent weather. My 96 only made 415rwhp with Kumho's and 3.73's and would run 11.6-11.7 all day long. Your 60' doesn't really seem to be bad but it should improve with practice. I think you should get the power checked on the dyno. Gen. 2 with that kind of power and mods should be in the 11's with no problem but to answer your question, the gears are NOT hurting you unless you need to get into 5th. Good luck!
Keith
2008 SRT10 Vert - 10.86 @ 128.29mph , All motor
MKB96Viper is offline   Reply With Quote
Old 08-03-2008, 05:48 PM   #5
29OUTLAW
Here are a couple of my slips. Somewhat apples to oranges but as you can see, your fine in the 2nd 1/8 mile. The first 1/8 miles is where you seem slow.
R/T .033
60' 1.999
330 5.260
1/8 7.896
MPH 94.55
1000 10.183
1/4 12.075
MPH 117.96
R/T -.124
60' 1.950
330 5.195
1/8 7.818
MPH 95.19
1000 10.101
1/4 11.903
MPH 118.43
29OUTLAW is offline   Reply With Quote
Old 08-03-2008, 06:07 PM   #6
grcforce327
Stop the guessing and put the car on a dyno!
Old 08-03-2008, 06:44 PM   #7
Camfab
Camfab's Avatar
I agree with above, your probably overestimating your power by about 60 - 75 hp. My guess is about 430 rwhp max. Gears are OK at your power level, the flywheel and the throttle bodies are probably hurting you. I think for the future you'd be better off with less gear or a bigger tire if you plan to make more power. Additionally, 12.23 is a great time for a viper and your mile per hour is good as well.
Old 08-03-2008, 09:12 PM   #8
anaconda666
Car was on a dyno last month. 435 hp at the rear wheels with bad valve springs. Had valve float at 5100 rpm so the guy setting up my AEM computer could only tune to that rpm. I since have had the springs replaced - can rev up to red line now but have not had the car tuned again. He figured I was losing around 50 hp at the top end because of the springs and lowered rpm range. Maybe 575 is a little over estimated but I know I should still be in the 11's. Thanks, Ron.
Old 08-07-2008, 12:48 PM   #9
1BADGTS
Bone stock on stock pilots i have seen excellent drivers pull 11.6-11.7 at 119 mph in Gen2s .With Drag radials on a stock car that equates to approx 11.3s.
1BADGTS is offline   Reply With Quote
Readings on 3.55 gears vs stock gears Viper44 RT/10 and GTS Discussions 8 11-09-2007 08:54 PM
Back hurting in the SRT-10 MannyC SRT10 and SRT10 Coupe Discussions 22 06-25-2004 08:59 AM
3.33,3.45,or 3.55 gears MOUNTAINWOLF RT/10 and GTS Discussions 3 11-22-2002 12:40 AM
where has everyone gotten there 3.54 gears from (Gen I)? bigr1 RT/10 and GTS Discussions 3 11-15-2002 12:07 AM
3.33 gears vs. 3.55 gears, Gen I Vipers??? 00prowler RT/10 and GTS Discussions 19 10-10-2002 03:25 PM
