Old 11-14-2005, 09:32 AM   #1
Vipera Russelli
Default Speedometer and Changing Wheel/Tires sizes
How much would the speedo be off if you put 20" all the way around on a Gen III? Or 19" in the front and 20" in the rear on a Gen III?
Anyone know where to get a speedo calibration certificate in Northern VA?
Vipera Russelli is offline   Reply With Quote
Old 11-14-2005, 09:57 AM   #2
Luke@tirerack
Site Sponsor / Vendor
Default Re: Speedometer and Chaning Wheel/Tires sizes
providing you keep the proper overall tire diameter there would be no difference
this picture explains it very well
Old 11-14-2005, 10:09 AM   #3
Vipera Russelli
Thanks Luke. I should have been more specific. Some folks here are filling up their wheel wells with larger wheels AND larger tires. I've done a search and can't seem to find what size tires these guys are using, but let's assume we're switching to 19" in front and 20" in the rear and using the same tire side wall as stock, so as to fill up the wheel wells while maintaining the stock rake. How much would you expect the speedometer to be off actual speed with this set up?
Old 11-14-2005, 11:00 AM   #4
Vipera Russelli
Thanks for calling me, Luke!
Old 11-14-2005, 01:02 PM   #5
Luke@tirerack
the rear SRT10 tire is 27.4" tall which is about 5% off of what you are loosing ..... so when your speedo says 105 mph you are only going 100 mph
Old 11-15-2005, 12:32 PM   #6
Nader
NY VCA Member
Nader's Avatar
I am interested to know whether the height of a 345/25/20 Pirelli is tall than the 27.4" stock tire height.
Luke do you know?
Old 11-17-2005, 08:56 AM   #7
Blue Batmobile
Blue Batmobile's Avatar
Isnt therev a website you can punch in your wheel and tire size and see the equivalent on upsizing? I know I've seen it before.
Bat˜
Blue Batmobile is offline   Reply With Quote
Old 11-22-2005, 09:57 AM   #8
Luke@tirerack
26.8" diameter
Wheel sizes IEATVETS RT/10 and GTS Discussions 6 02-05-2007 02:19 PM
(FYI) Brand New Tires 18" OEM Sizes on E bay $ 1.200.00 SSSSE YA RT/10 and GTS Discussions 1 04-14-2006 03:28 AM
track wheel sizes, pros and cons Catwood RT/10 and GTS Discussions 10 09-28-2005 01:59 PM
What tires and sizes are you 19" guys running ? twinvipers RT/10 and GTS Discussions 6 11-16-2004 04:40 PM
Wheel sizes Fasteddie SRT10 and SRT10 Coupe Discussions 3 11-12-2004 09:29 AM
