Old 12-07-2005, 09:58 AM   #1
Nader
NY VCA Member
Nader's Avatar
Default Tire Flat Spots - Non Run Flats
I recently added an HRE setup to my Viper 19's and 20's with Pirellis. My question is since the car will sit for periods of time during the winter when the weather is not agreable, should I worry about developing flat spots on the tires? I had a 911 with Pirellis and it developed flats spots quite quickly.
If there is a concern, what can i do to minimize it? Can I sit the car on something softer like rubber padding? I am sure someone makes something to rest the tires on to miminize this.
Old 12-07-2005, 02:54 PM   #2
Warp10
WA VCA Member
Warp10's Avatar
Default Re: Tire Flat Spots - Non Run Flats
I don't have Pirellis on my car. I have the stock run-flats. I usually pump up the tires to about their max pressure for the winter. Another Viper owner suggested heavy rubber matts under the tires. Sometimes ranches will use "stable mats" for the horses for something softer to stand on. I have two 4 X 8 pieces my car sits on. No problems with flat spots so far. On any nice winter days I back the car out and then pull it in so that the tires do not rest on the same spot for about a week or two at a time.
Hope this helps
Warp10 is offline   Reply With Quote
Old 12-07-2005, 03:00 PM   #3
Nader
NY VCA Member
Nader's Avatar
I also try to move the car every week or so. However the difference between run flats and the non run flat Pirelli's is substantial. The run flats are a much heavier, thicker tire which makes them prone to flatspotting. However the softer Pirellis in my experience may develope issues if I dont address it now.
I was thinking about getting these but they are quite expensive. I wonder is a heavy rubber mat would do just the same.
http://www.tirecradle.com/tcradle.htm
Old 12-08-2005, 02:58 PM   #4
Luke@tirerack
Site Sponsor / Vendor
the Tire cadle works great
carpet helps
foam padding helps
higher air pressure helps
Old 01-18-2006, 08:52 PM   #5
Boxer12
Boxer12's Avatar
There are rubber mats you can buy that claim to prevent this problem. I think you can find them in Road & Track ads.
Boxer12 is offline   Reply With Quote
SRT 10's, Run Flats, and Tire Pressure Warning System Bobpantax SRT10 and SRT10 Coupe Discussions 10 04-08-2007 06:06 AM
What are my option with a flat tire? juniormint RT/10 and GTS Discussions 14 04-25-2005 11:19 AM
Run flats off, non run flat on, ahhh Viperized SRT10 and SRT10 Coupe Discussions 14 02-12-2005 06:42 PM
Avoiding flat spots during winter storage Go Fast For Life General Viper Discussion 14 12-30-2003 07:00 PM
Just got my flat-spots fixed ntmatter RT/10 and GTS Discussions 7 02-27-2002 11:37 AM
