Old 01-05-2006, 04:36 PM   #1
Dawg2Snake
AZ VCA Member
Dawg2Snake's Avatar
Default Drag Radial wheel/ tire size
Does anyone know the smallest diameter rims you can put on a Gen 3? I want to get a set of drag radials for the rear on some relatively cheap rims for drag strip only. Stock rears are 19" - does anyone have experience with 18" or even 17 or 16? What is the minimum to clear the calipers?
Thanks in adavance!
Dawg2Snake is offline   Reply With Quote
Old 01-10-2006, 04:46 PM   #2
Luke@tirerack
Site Sponsor / Vendor
Default Re: Drag Radial wheel/ tire size
18's are the smallest and you need to remove or relocate the parking brake caliper
Wheel width and Tire size for a GTS? OKViper RT/10 and GTS Discussions 9 03-31-2007 03:42 PM
Which size wheel/tire is best for serious street diabolos88 RT/10 and GTS Discussions 3 07-20-2005 08:49 AM
drag wheel/tire options acrdakota RT/10 and GTS Discussions 1 03-06-2005 03:03 PM
Need some Drag Radial Tire help for... Anthony - 98 GTS RT/10 and GTS Discussions 10 02-05-2002 11:15 AM
Drag wheel / tire choices Supercharged Vipermad Performance Modifications 6 03-22-2001 11:26 AM
