Old 02-09-2006, 03:12 PM   #1
viper spray
Default How does tire height effect gearing?
I have 3:55s and CCW slicks and skinnys , I want the best drag tire for the rears that will fit, and compensate for my bad gear choice for drag racing. My car makes 701 RWHP. Which tire size do I need?
thanks
viper spray is offline   Reply With Quote
Old 02-10-2006, 09:23 AM   #2
Luke@tirerack
Site Sponsor / Vendor
Default Re: How does tire height effect gearing?
in simple terms a shorter tire = a higher gear ratio ....
the original 17" tire diameter in the rear was 26.0" with 789 revolutions per mile ...
we only carry the BFG drag radial tire and they really do not offer a good size for the Viper .... the widest 17" tire they have is a 315 which will not help your situation at all .... I do not know all of the sizes available from the other DR tire companies out there .... is you could find a 335/30-17 that would give you a 25" diameter tire amking your 3.55's act like 3.73's
Old 02-11-2006, 08:56 PM   #3
Jack B
Jack B's Avatar
Luke's theory is ok for a stock car, but, you have to much power. If your car (700hp)is driven to its full potential on the drag strip you probably have too much gear (with 26" tires and 3.55 gears)and might have to shift to 5th gear to finish the quarter. You should be tracking close to a 140 mph with that hp. A trip to the track will tell you very quickly. The other problem is that 28" tires don't always fit our cars, it takes some modification.
Perfect GEN II gearing. OKViper RT/10 and GTS Discussions 14 04-22-2007 10:52 PM
Low Pressure Tire Light, What does it effect? orlandov10 SRT10 and SRT10 Coupe Discussions 23 03-03-2006 03:22 PM
what is the best gearing ? wbexxon SRT10 and SRT10 Coupe Discussions 17 10-30-2005 06:45 PM
ACR,GT-2,GTS all have the same gearing? 2charmed Archive Management 1 04-09-2001 04:15 PM
