Old 05-30-2006, 02:22 PM   #1
snakebitdave
snakebitdave's Avatar
Default Tire pressure lesson
Last week I had new tires (PS2's) put on my '96 and took it on the expressway yesterday. When there was no traffic ahead I ran it up to 120mph when the car became very loose side to side; scary in fact. I found that the "technician" had put 55 psi in the left rear tire and 35 in the others. Lesson learned-don't assume anything.
snakebitdave is offline   Reply With Quote
Old 05-30-2006, 03:35 PM   #2
JonB - PartsRack
Site Sponsor Since 1998
JonB - PartsRack's Avatar
Default Re: Tire pressure lesson
"It's NOT Your Fathers Oldsmobile"
The Viper chassis is so stiff, that even 4-5 PSI variance across left-right can result in a push to the low side. In effect, it sets up a NACSAR "stagger" with a taller tire. Will also cause a low-side pull under braking.
The same thing happensif you destroy one tire, and replace just that one tire. You have a taller new tire, maybe 4-5-6/32" taller, opposite the shorter used one. NOT SAFE!
I have seen good heads-up results with those Auto-Zone style VALVE STEM INDICATORS, where a green button displays when full, and changes colors to yellow or red as the pressure goes away..... It wont protect against the moron who put 55 PSI in once, but it could save your butt vs. a slow leak, VERY COMMON!
Old 05-30-2006, 03:58 PM   #3
radta7
Illinois VCA Member
radta7's Avatar
Dave,
What do you think of the PS2's??? Esp after you put the proper pressure in?
radta7 is offline   Reply With Quote
Old 05-31-2006, 10:05 AM   #4
Racer Robbie
New England VCA Member
Racer Robbie's Avatar
Jon is 100% correct in what he is telling you guys. Those Autozone pressure sensors do work. But the tire guy who put in 55 lbs should not be calling himself a "technician", sounds more like a back yard mechanic to me.
Robbie
Old 05-31-2006, 10:52 AM   #5
Got Venom
NorCal VCA Member
Got Venom's Avatar
I can not believe all the money everybody puts in their cars, and they don't watch their tire pressure. That one day you decide to go 150 mph, and you did not notice that there was a screw in your tire, and you started out with only 15 psi in your tire??? That is why I installed the "Smart Tire" system on my car. The next time you change tires, or if you just want piece of mind, the Smart Tire system is a band that runs around the center of your rim, and it gives you pressure within 1/2 a pound and Temp of each tire as well. It also has alarms that go off if it exceeds a certain drop in pressure or rise in temperature. I pull out of my garage, and every tire is 29 psi exactly. Then after driving 15 minutes they are up to 32 PSI and it is only 60 degrees out. It sure gives me piece of mind, knowing I can read any tire's pressure within 1/2psi at any time. especially before I am going to go fast.
Got Venom is offline   Reply With Quote
Old 05-31-2006, 02:37 PM   #6
Wild Bill
Wild Bill's Avatar
So how much did the Smart tire system cost?
B
Wild Bill is offline   Reply With Quote
Old 05-31-2006, 03:42 PM   #7
DavidSB
DavidSB's Avatar
I've run a SmartTire system in my 4WD offroad van for 5 years. The internal batteries are just now begining to fail. It's saved me 3 times in as many years so I could change the slow leaking tire in a safe location with the alternative having a tire failure on steep, rock crawling, switchbacks.
Friends and I have bought the system and replacement parts from Shaun at Bob Dickman Tire, Junction City, OR 800-257-8430. They sell lots of SmartTire system to Class A RV's and trailers. Tell Shaun that David with the Sportsmobile from Santa Barbara recommended him.
DavidSB is offline   Reply With Quote
Old 06-01-2006, 09:09 AM   #8
Racer Robbie
How about the companys web site for this smart system?
Old 06-01-2006, 03:43 PM   #9
Luke@tirerack
Site Sponsor / Vendor
I believe they prefer the term "Shadetree mechanic"
Old 06-01-2006, 06:55 PM   #10
Got Venom
NorCal VCA Member
Got Venom's Avatar
I can not remember how much, because I had a bunch of work done at the same time, but I think the system is around $250.00 and to install it is cheaper if you are changing out tires anyway, but if not, you have to consider how much they will charge you for dismounting and installing the sensors on the center of the rim, and remounting, and rebalancing your tires. I think that day I did alignments and everything else, and it was $500 total?? It has been over a year now though. Here is the company's website.
http://www.smartire.com
Old 06-01-2006, 11:12 PM   #11
Randy
Randy's Avatar
Do a google search for the system - I bought a second system last summer and the best price I found was from a place called Vulcan Tire, as I recall, for about $50 cheaper than other places ($220? or so, as I recall). TireRack used to sell them, but didn't have the best price.
Old 06-02-2006, 08:33 AM   #12
Luke@tirerack
we still do .....
Old 06-02-2006, 12:35 PM   #13
Racer Robbie
Shadetree mechanic is a good one luke. How much is your system?
Old 06-02-2006, 03:38 PM   #14
Luke@tirerack
$249.00 basic system
$49.00 full function remote display
Old 06-03-2006, 04:41 PM   #15
Racer Robbie
That's cheap insurance. I will be installing next time I need tires.
Thanks Luke,
Robbie
Tire pressure Sandy G SRT10 and SRT10 Coupe Discussions 10 12-27-2006 08:15 AM
Tire Pressure 97 GTS BL/WH RT/10 and GTS Discussions 3 11-17-2006 07:55 PM
Tire pressure lesson snakebitdave General Viper Discussion 0 05-30-2006 02:22 PM
Tire Pressure Jeremy '95 Viper RT/10 and GTS Discussions 8 04-25-2004 08:38 AM
Tire Pressure????? bad viper Archive Management 2 11-07-2000 06:13 PM
