Old 07-10-2006, 10:05 PM   #1
Dawg2Snake
AZ VCA Member
Dawg2Snake's Avatar
Default Gen III tire pressure sensors
If I upgrade from stock rims to aftermarket, do I keep the original sensors? Can I order new ones from Dodge, and if so, how much do they cost? Anyone with experience here, feel free to help me out.
Thanks!!
Dawg2Snake is offline   Reply With Quote
Old 07-11-2006, 12:01 PM   #2
Luke@tirerack
Site Sponsor / Vendor
Default Re: Gen III tire pressure sensors
in some can re-use the original sensors but, not all wheels are designed to accept them correctly. So, be careful in your wheel choice and make sure to verify that they will accept the sensors properly. Some companies that have not designed their wheels for the TPMS sensors will tell you to epoxy and strap the sensors to the wheels DO NOT fall for this ploy as it is not correct and can / will cause you problems down the road
Old 07-11-2006, 03:21 PM   #3
Dawg2Snake
AZ VCA Member
Dawg2Snake's Avatar
Do you know if the factory sensors fit in HRE rims? Thanks for your advice.
Old 07-13-2006, 07:49 AM   #4
Luke@tirerack
I don't know the answer to your question exactly ....
HRE may have changed their wheel design to accomodate the sensors but, in the past they sensors had to be strap mounted
Wanted: 2 Tire Pressure sensors for gen 3 wheels steve911 SRT10 and SRT10 Coupe Discussions 1 03-19-2007 02:09 PM
How Do I reset TIRE PRESSURE SENSORS? 2002_Viper_GTS_ACR SRT10 and SRT10 Coupe Discussions 11 09-16-2006 03:40 AM
STOCK AIR PRESSURE SENSORS Racer Robbie SRT10 and SRT10 Coupe Discussions 30 07-12-2006 11:11 AM
Wheel tire pressure sensors - more rleminv SRT10 and SRT10 Coupe Discussions 3 03-03-2006 11:12 PM
Tire Pressure Sensors and Track Wheels Kai SRT10 SRT10 and SRT10 Coupe Discussions 30 04-12-2005 12:26 PM
