Old 08-30-2006, 09:46 AM   #1
Vipermann1
Default Correct Tire Pressure???
Ok, I got different answers from different sources, so I am asking the experts.
On a 2000 Viper RT/10, with the stock factory wheels and stock factory Pilot Sport tires: What is the correct Tire Pressure??
Thanks,
UZY
Vipermann1 is offline   Reply With Quote
Old 08-30-2006, 01:43 PM   #2
GTS Bruce
GTS Bruce's Avatar
Default Re: Correct Tire Pressure???
29
Old 08-30-2006, 04:07 PM   #3
Luke@tirerack
Site Sponsor / Vendor
29 front & 29 rear is what Dodge recommends but, the car will handle better running 34 front 30 rear
Old 08-30-2006, 11:47 PM   #4
Randy
Randy's Avatar
I run 29 front 31 rear - seems to even out the wear a little better.
Old 08-31-2006, 02:45 PM   #5
Luke@tirerack
that would increase the understeer the car already has
Old 09-07-2006, 04:40 PM   #6
Warp10
WA VCA Member
Warp10's Avatar
Anyone have a recommendation for tire pressures on the track and road course at VOI 9? This would be for stock SRT-10 wheels and tires. Thanks.
Warp10 is offline   Reply With Quote
Old 09-07-2006, 09:03 PM   #7
DavidSB
DavidSB's Avatar
I've been running 34# cold on 50-60 degree mornings at Viper Days events which results in 40# as soon as I finish a half-hour lapping session. Stock wheels and run-flats.
DavidSB is offline   Reply With Quote
Old 09-08-2006, 03:08 PM   #8
Warp10
WA VCA Member
Warp10's Avatar
Thanks, David
Old 09-12-2006, 01:06 PM   #9
snampro
snampro's Avatar
how about a stock '94 RT/10 with stock 17" wheels and Pilot Sports?
Old 09-13-2006, 07:51 AM   #10
snampro
snampro's Avatar
bueller? bueller?
Old 09-13-2006, 03:27 PM   #11
mcmike
I just ran my Viper SRT-10 at Willow Springs International Speed Way (California)... Air temperature was about 90 degrees. I was running STOCK Michelin Sport tires (Run Flats) 18" front 19" rear. My starting tire temperature was 33# after running 3 warm up laps and 3 race laps... I checked the temperature and it was at 40#. After taking my car to the TIRE GARAGE... He verified the tire temperature was PERFECT! He took off each tire and verified that the ware was even on all tires. This should help you for Viper Days... Temperature should be 90+
Mike
mcmike is offline   Reply With Quote
Old 09-13-2006, 03:56 PM   #12
snampro
snampro's Avatar
my problem is my manual and car say 36 PSI, but I know that is wrong because the original VIPER tires aren't made anymore and the pilot sports are significantly different. I have heard 29 and 30 psi, but I saw this post and figured I'd get another opinion. I generally run 30 PSI at all four corners, there was a huge improvement in handling when I stopped using 36 like the manual said.
Correct tire pressure? n-mo RT/10 and GTS Discussions 8 04-06-2007 05:34 AM
Tire pressure Sandy G SRT10 and SRT10 Coupe Discussions 10 12-27-2006 08:15 AM
Correct tire pressure? Sellshomesdrivesviper SRT10 and SRT10 Coupe Discussions 10 10-20-2005 02:57 PM
Tire Pressure w/in >>> pdmracing RT/10 and GTS Discussions 1 09-18-2001 05:11 PM
Tire Pressure????? bad viper Archive Management 2 11-07-2000 06:13 PM
