Old 12-13-2006, 02:54 PM   #1
Luke@tirerack
Site Sponsor / Vendor
Default Tire Pressure Monitoring Systems
CHRYSLER/DODGE
An Update on Tire Pressure Monitoring Systems and Aftermarket Wheels
A direct tire pressure monitoring systems (TPMS) will be standard equipment on every vehicle sold in the U.S. after September, 2007. The criteria for TPMS standardization is that the vehicle must have only four wheels (no dual-wheeled trucks or motorcycles), and weigh less than 10,000 lbs.
Chrysler and Dodge are keeping up with the new TPMS law. Many of the cars and vans already have direct TPMS (see TPMS facts below), as do the 2007 SUVs, but the pickup trucks do not have the option yet. Chrysler and Dodge currently use several sensors from Siemens and Schrader. The Tire Rack carries all sensors for vehicles up to the 2007 model year. The size of the sensor shouldn’t be a problem for many wheels, but if the valve hole is in the middle of the wheel’s barrel, the sensor will not fit properly. Wheel manufacturers are aware of the issue and are rushing to get most of their wheels TPMS-compatible.
The Tire Rack's fitment specialists have carefully determined which wheels that are currently available will be compatible with the system installed on your vehicle.
If you have any questions about the wheel you're considering, call or post your question for confirmation that it will be compatible with your TPMS.
TPMS Facts
Direct TPMS use a sensor in the wheel/tire to wirelessly relay pressure back to the driver via a display inside the vehicle. Some vehicles have a digital screen that continuously shows all four tire pressures (five if spare has sensor). Others simply flash a "low tire pressure" light on the dash. Additionally, there are two different styles of sensors for a direct system: a valve sensor and a strap/band sensor. Only valve sensors are used on Chrysler/Dodge direct system-equipped vehicles. If you bought an aftermarket SmarTire TPMS, its sensors are held on by a strap around the barrel of the wheel.
Indirect systems work in conjunction with the ABS wheel speed sensors that “count” the number of revolutions of each tire. If the right front tire is low (25psi) it will spin faster than the left front tire (35psi). The ABS system will recognize this change and alert the driver with a flashing light and possibly a loud chime. Although no current model Chrysler or Dodge has an indirect TPMS, it is helpful to understand this important difference -- indirect systems do not affect the fitment of aftermarket wheels.
Old 01-10-2007, 06:56 AM   #2
97 GTS BL/WH
97 GTS BL/WH's Avatar
Default Re: Tire Pressure Monitoring Systems
Can you give me some comparisons on the models you carry. I notice you carry both the Smartire and WTPMS.
The WTPMS head unit looks better than the Smartire, but which one works better for the Viper?
97 GTS BL/WH is offline   Reply With Quote
Old 01-10-2007, 02:31 PM   #3
ILLSMOQ
Do you guys have the straps to mount the sensor inside the barrel of the wheel. I had a strap fail on one of my HRE's.
Old 01-10-2007, 08:42 PM   #4
Randy
Randy's Avatar
From a consumer's standpoint, I've been very satisfied with the SmarTire system; I've had it on two Vipers, works very well.
Old 01-11-2007, 10:56 AM   #5
BruceW
I have had the Smartire system over a year, works great. Mine came with the sensors mounted onto the inside part of the valve stem, not banded to the inner rim.
BruceW is offline   Reply With Quote
Old 01-11-2007, 02:10 PM   #6
ILLSMOQ
540R style valve stem? Any idea how to get that hardware?
Old 01-15-2007, 11:23 AM   #7
Luke@tirerack
while I really like both systems we are currently in negotiations for a better / more informative system which we should have by early next month
Old 03-04-2007, 09:43 PM   #8
KepRght
KepRght's Avatar
any word on the new system?
KepRght is offline   Reply With Quote
Old 03-05-2007, 09:06 AM   #9
Racer Robbie
New England VCA Member
Racer Robbie's Avatar
Luke,
Is there a way to get the dash read out on 2003 and up SRT-10 vipers to show the true pressures of the 4 tires instead of just a low reading?
Old 03-20-2007, 06:49 PM   #10
KepRght
KepRght's Avatar
Luke, i need to order tires for my new wheels tomorrow. i want to order a TPMS that displays the pressures of each tire. do you have such an animal, or can you point me at a good system? thanks.
Old 03-20-2007, 08:41 PM   #11
Randy
Randy's Avatar
The SmartTire system give pressure and temperature for each wheel, and attempts to map the pressure/temperature curve to give appropriate alerts, so I'm intrigued, what "more informative" additional data are you looking at?
Old 03-20-2007, 09:29 PM   #12
KepRght
KepRght's Avatar
randy, i dont see the system you are talking about on the tire rack site
http://www.tirerack.com/accessories/tpms.jsp
Old 03-20-2007, 09:32 PM   #13
KepRght
KepRght's Avatar
ya, its not listed on tirerack
here it is
http://www.smartire.com/automotive
For drivers wanting more detailed tire monitoring data, SmarTire offers either a Full Function Display or a Full Function Remote Display. These products offer digital pressure and temperature information through a fully programmable LCD display. The Full Function Displays automatically identify the nature and location of pressure or temperature irregularities and allows the driver to read the tire temperature and pressure status by scrolling through each tire position.
Three levels of warnings are provided including an audible and visual indication of a deviation from required pressure, a significant drop in tire pressure levels and, excessively high temperature. The Full Function Remote Display offers the same important information and alerts, but allows for a number of installation options.
Old 03-21-2007, 01:10 AM   #14
Randy
Randy's Avatar
Yah, I was asking Luke what extra information that the system they were considering was going to give. (I was not meaning to imply nor say that TireRack carried SmarTire, although TireRack *used* to carry SmarTire a few years ago).
I've got the SmarTire full function display built into the middle vent of my Viper, looks very professional with the bezel that a friend made.
Old 03-21-2007, 06:44 AM   #15
Dave Moore
Dave Moore's Avatar
I have the smart tire system with the full function display an it is great. temps and pressures at all 4 tires. The display unit is a small rectangular piece (still searching for a permanent mounting location). I have even had good responses from their technical support prople.
I think parts rack still sells this unit.
Dave
Dave Moore is offline   Reply With Quote
SRT-10 Wheel/Tire Pressure Monitoring System ?'s 1MEANSNAKE SRT10 and SRT10 Coupe Discussions 0 12-07-2004 02:50 PM
best tire pressure for SRT? MaxedGTS SRT10 and SRT10 Coupe Discussions 17 08-08-2004 08:38 PM
Tire Pressure Monitoring System 99BLKRT/10 RT/10 and GTS Discussions 7 01-06-2004 04:28 PM
anyone using smarttire pressure monitoring system? bad viper RT/10 and GTS Discussions 2 01-27-2002 06:08 PM
Wireless Air Pressure Monitoring Ron RT/10 and GTS Discussions 7 12-04-2001 12:49 AM
