Old 03-08-2007, 11:43 AM   #1
1ylwvpr
Default Question about Gen 3 brakes on a 2001 Gen 2 car.
Has anyone installed a Gen 3 brake booster onto a 2001 Gen 2 car?
I recently installed Gen 3 brakes onto my 2001 Gen 2 Viper. I have not tried them on the track yet, but from the one time I had the car on the street they seem to be a big improvement. However, they do not have the feel of the Gen 3 cars awesome pedal feel. There is still a long travel in the pedal and not as solid as the Gen 3's. I was wondering if a Gen 3 brake booster would make it like a Gen 3 car? Any input would be appreciated!
1ylwvpr is offline   Reply With Quote
Old 03-10-2007, 11:45 PM   #2
KepRght
KepRght's Avatar
Default Re: Question about Gen 3 brakes on a 2001 Gen 2 car.
i have gen3 brakes on my 01 gen2 pedal is real firm.
do you have stainless brake lines? that will change pedal feel quite a bit. who did the fluid bleed? that can change it allot. if you did it try a bleed vacuum, and bleed them again after you change the lines.
i don't have a gen3 booster on the car. only the master cyl. i cant comment.
talk to valaya racing 408-297-1990 they have done a ton of gen2 -> gen3 conversions and have the info you seek.
KepRght is offline   Reply With Quote
Old 03-11-2007, 09:23 PM   #3
1ylwvpr
I do have stainless brake lines on the car already. I did the brake bleed myself with a friend. We did it by pumping the pedal and cracking open the bleeder valve. Although it seemed like I got all of the air out, its hard to be sure 100% of it is out. I'll call Valaya to see what they can tell me. Thank you for the information!!!
Old 03-13-2007, 11:46 PM   #4
KepRght
KepRght's Avatar
no problem bro! post an update with what fixed the issue
Old 03-14-2007, 11:39 AM   #5
Schulmann
VCA Regional President Quebec
Schulmann's Avatar
The booster is enough large but some people change the master cylinder.
It is on my project list.
Gen3 master cylinder has more volume and this is what will improve your feeling.
Stainless steel break lines only matter when your breaks are red hot ... above 270F.
Old 05-22-2007, 06:25 PM   #6
Viper X
So Cal VCA President
Sounds like an "air in the brake lines" or master cylinder issue.
I too have the Gen III brakes, SS lines and like the feel on the track. True, they are not as powerful / easy to engage firmly as the Gen III's but I think the feel is better, very progressive.
I recently upgraded to Mintex brake pads (some comp coupe's run
these). Big difference. They are almost too touchy and powerful. My GTS really stops now.
Good luck,
Dan
2006 VOI9 Coupe
Old 05-23-2007, 09:04 AM   #7
Bugeater
ViperX - Where did you source your Mintex pads, and how much?
Track: 1996 Silver/Blue/Black/Red RojoFro Racing #65 SCCA ITE, ViperDays GT-1
Street: 2000 Dinan M5, 2007 Turbo Mini
Sold: 2000 Black ACR
Bugeater is offline   Reply With Quote
Old 05-23-2007, 01:57 PM   #8
REDSLED
I've purchased them through Parts Rack.
I've also used the Brake Man 4's. Not as grabby
as the Mintex or PFC, but very consistent and long lasting.
REDSLED is offline   Reply With Quote
Old 05-23-2007, 02:23 PM   #9
Bugeater
Brakeman 4's? Eeeeeew. Not as grabby as 3's and I thought 3's sucked compared to PFC 01's...Maybe 4's would be ok with the GEN III - much larger piston sizes, pad surface area and additional torque (due to 14" vs. 13" rotor) but with a stoptech setup Brakeman 4's were, um, bad.
Old 05-27-2007, 11:13 PM   #10
REDSLED
Went back to the track today and yikes John, you were right. Ran 1 session with the Brakeman 4's then switched them out to the Mintex and the difference was night and day. The initial bite of the Mintex was far superior than the Brakemans. I will keep the Brakeman 4's as a last ditch back up. The PFC 01's are also a favorite of mine as well as the Pagid Blacks.
Old 06-06-2007, 07:43 PM   #11
Viper X
Bugeater,
I bought the Mintex pads from Archer Racing at a Viper Days event. Right around $450 - $500 for the set as I recall. It was a very warm day and my stock pads were failing.
I put the Mintex pads on and boy, do they stop you!
No sure how long they'll last or what they'll do to my rotors but they really work well.
Dan
2006 VOI9 Coupe
SRT-10 brakes fit on a 2001 GTS? Docta Vipa Performance Modifications 11 03-06-2003 10:02 AM
srt - 10 brakes for my 2001 acr Fast Freddy RT/10 and GTS Discussions 1 02-09-2003 08:37 PM
2001 Brakes Supercharged Vipermad Archive Management 5 01-20-2001 11:20 PM
2001 and ABS brakes....WOW! KWIK Archive Management 1 01-05-2001 10:46 PM
2001 BIG Brakes are Coming Soon! dtittle Archive Management 0 12-18-2000 12:18 AM
