Old 03-25-2008, 05:38 PM   #1
Alley
Default 315's ok for a 17" rim?
Will the Nitto 315/35/17 Drag Radials work with stock Gen I rims? Or is there another drag radial that is wider that you would recomend and be ok for mostly street use.
Alley is offline   Reply With Quote
Old 03-25-2008, 05:55 PM   #2
chimazo
Virginia Maryland VCA Member
chimazo's Avatar
Default Re: 315's ok for a 17" rim?
Not sure why you'd want a drag radial for mostly street use, much less one that's narrower than stock, but Hoosier makes a 335/35/17 DOT tire. It's really a strip tire that you can drive to the track, and you'd kill yourself if the street was wet. Basically a slick with some grooves in it.
'08 Hummer H3
Old 03-25-2008, 05:58 PM   #3
Alley
Well, there might be some racing on said street once in a while. I looked into the Hoosiers but like you said, there more of a slick and I wanted something that would be ok if I get caught in the rain or something. Even though there narrower then stock I was thinking since there a drag radial they would still hook up better. I'm deffinatly open to suggestions.
Old 03-25-2008, 06:03 PM   #4
chimazo
chimazo's Avatar
If you went to an 18" rim, you'd have more choices in a 335 or 345 drag radial better suited for the street, but you probably knew that...
'08 Hummer H3
Old 03-25-2008, 06:03 PM   #5
Alley
Ya, not interested in new rims at the moment. So will the Nitto's even work, or are they too skinny? Or would you just plain not reccomend going more narrow then stock?
Anybody with 315's front tires on 11.5" wide rims? Vypr Phil SRT10 and SRT10 Coupe Discussions 2 12-30-2007 04:27 PM
Anybody running 315's front on 11.5" wide rims? Vypr Phil Tire , Wheel, Brake and Suspension 0 12-29-2007 12:44 AM
AlansPerformance.com ""Cool Triple Pass Radiator"" BLWNV10 New Products, Supplier Specials, and Group Buys 1 08-23-2007 12:26 PM
Mail me a used "1" from "RT/10" red rear emblem Please! ZEUS RT/10 and GTS Discussions 3 08-16-2007 05:06 PM
