Old 04-18-2008, 06:40 AM   #1
JayW1
Florida VCA Member
JayW1's Avatar
Default Are PS2's unidirectional?
While installing a big brake kit I just noticed that my relatively new Michelin PS2's appear to be unidirectional and it looks like I have four lefts or four right tires (the tread curves in opposite directions on the right and left tires).
I am trying to confirm if the vendor that sold me these tires made a mistake so I can get it corrected. Any help would be appreciated.
JayW1 is offline   Reply With Quote
Old 04-18-2008, 10:16 AM   #2
JayW1
Florida VCA Member
JayW1's Avatar
Default Re: Are PS2's unidirectional?
Well, as strange as it seems, I spoke with someone at Michelin and he stated that they are not unidirectional. I don't know much about tire design but apparently the direction of the tread has little to do with how they perform
At least I don't have to send two of them back.
Old 04-18-2008, 10:38 AM   #3
ViperGTS
VCA Member Bavaria
ViperGTS's Avatar
I bought PS2s recently and they have a clear marking "OUTSIDE".
www.viperclub.de
- no speed limit -
Old 04-18-2008, 03:47 PM   #4
VIPER BAZ UK
UK VCA Member
VIPER BAZ UK's Avatar
Just put 4x PS2's on as well,, and they all say OUTSIDE as stated above.........
Baz
VCA SAVED TATORS DODGE!!!!!!!!!!!!!
Old 04-19-2008, 06:48 AM   #5
Luke@tirerack
Site Sponsor / Vendor
the PS2 is not a directional tire ... even though it sort of looks like it might be ... it is an asymetrical tread design
For more info on any post
Old 04-19-2008, 06:31 PM   #6
JayW1
Florida VCA Member
JayW1's Avatar
Thanks for the responses guys. The tires are all mounted correctly in terms of asymmetry (the outside is out) but what I was refering to is the tread pattern. If you look at your PS2's really close, the tread on the outside of the tire on the right is curved toward the front of the car and on the left toward the rear of the car. It is a subtle difference that is easily seen when you have both tires off the car sitting side by side. Like Luke said, they look like they should be unidirectional.
Old 04-19-2008, 06:33 PM   #7
ViperTony
ViperTony's Avatar
Did Luke say Unidirectional or Symmetrical? What's the difference?
WE SAVED TATOR'S DODGE
Old 04-19-2008, 07:39 PM   #8
JayW1
Florida VCA Member
JayW1's Avatar
Asymmetry is when there is a different tread pattern on each half of the tire. In other words, there is an inside and outside and it has to be mounted that way. Unidirectional (or simply directional) means that the tire was meant to rotate in one direction and therefor you need different tires for the right and left sides to perform properly.
Old 04-21-2008, 03:49 PM   #9
ViperJohn
Virginia/Maryland VCA Vice President
ViperJohn's Avatar
I am glad you posted this because I was going blind trying to find if there was a directional arrow anywhere on the tread.
ViperJohn is offline   Reply With Quote
Old 04-24-2008, 02:24 PM   #10
wastntim
Illinois VCA Member
wastntim's Avatar
Hear Hear! I was majorly confused when I went to intal my ps2's. I knew that they were mounted correctly as they all said outside, but looking at the tread and seeing it going in differnet directions was maddening!
Robert
PS2's are on!!! voi9 SRT10 and SRT10 Coupe Discussions 25 02-22-2008 10:42 PM
PS2's VS Runflats Bobpantax SRT10 and SRT10 Coupe Discussions 1 02-16-2008 03:21 PM
345/30-19 PS2's (the '08 VIPER has PS2's) snampro Tire , Wheel, Brake and Suspension 2 02-08-2007 07:29 AM
17" PS2's??? radta7 Tire , Wheel, Brake and Suspension 5 04-06-2006 06:37 AM
Unidirectional tires V10 MOJO RT/10 and GTS Discussions 1 05-10-2003 01:26 PM
