Site Sponsor / Vendor
Disc Brake Australia
![]() 5000 series ![]() 4000 Series ![]() DBA 2-piece 5000 series fronts and 1-piece 4000 series rear $1298.00 per set plus shipping (Gen 1 & 2) $1196.00 per set plus shipping (Gen 3) $632.00 per set plus shipping for Series 4000 front and rear (Gen 3 only) __________________________________________________ _____________________ With a two-piece design and a black Alumalite™ centre hat, DBA's 5000 series slotted rotors complement the looks of a great looking performance car. As with every DBA rotor, the 5000 Series 2-Piece rotor bolts right onto the vehicle with no mechanical changes needed. __________________________________________________ ____________________ The 4000 Series Wiper-Slot rotor has a unique 6x6 slotted design for extreme stopping power on the road and the track. As with every DBA rotor, the 4000 Series rotor bolts right onto the vehicle with no mechanical changes needed. DBA's mid-series, enhanced-performance, slotted rotor features Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. __________________________________________________ ___________________ All 5000 Series rotors and many 4000 Series Rotors feature Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. ![]() TSP is a propriety process specifically developed by DBA for improving the performance of disc brake rotors. Benefits of TSP include:
![]() Thermo-Graphic markings are placed on the outer edge of each DBA 5000 series disc rotors and are used to monitor the core temperatures achieved during braking application. The markings change color as the rotor heats up to alert the driver to rotor temperatures that exceed optimum levels. ![]() ''Kangaroo Paw'' is a patented, high-tech disc rotor ventilation system designed and manufactured in Australia by Disc Brakes Australia and available on rotors for select applications. "Kangaroo Paw" technology delivers significantly improved braking performance. Even under extreme braking conditions. Kangaroo Paw rotor designs run cooler, are stronger, and outperform traditional straight-vane disc rotors. ![]() The ''Kangaroo Paw'' design features a series of 144 diamond- and tear drop-shaped pillars and columns individually spaced between the rotor faces. This system provides two key advantages. First, is the ability to cool the rotor faster than ever before. As the disc rotor rotates, aerodynamic turbulence around the individual pillars and columns is generated, increasing the force of hot air out from within the internal areas of the rotor. Second is increased dimensional stability across the disc rotor directly achieved by the individually spaced pillars and columns. These advantages increase the disc rotor's efficiency by as much as 20% when compared to conventional rotor designs. A 20% increase in disc rotor efficiency directly translates to reduced brake operating temperatures, brake fade, disc rotor stresses, disc thickness variation, run-out and shudder. All 5000 series rotors also benefit from DBA's "Longlife Slotted" design. The rotors are manufactured to QS-9000 quality standards using premium grade materials with a high iron content and dense metal matrix resulting in long wear and safe, consistent stopping power.
you can call me directly or use this link to place your order http://www.tirerack.com/a.jsp?a=BO1&url=/brakes/index.jsp
For more info on any post or to place an order please call me directly @ 877-522-8473 ext. 362 or use my name for on-line orders |
no calls about these after all of the questions in the past .... that's interesting
Post a pic of the actual rotors....those pics above are not very impressive.
| Brake rotors/Brake pads | Russ M | RT/10 and GTS Discussions | 20 | 12-31-2003 12:45 PM |
| ViperRacing Disc Brake Clocks available for immediate shipment | ViperRacing | Merchandise, Collectibles, Memorabilia, Apparel, and Miniatures | 0 | 12-03-2001 02:36 PM |
| Viper Racing Disc Brake Clocks available for immediate shipment | ViperRacing | RT/10 and GTS Discussions | 0 | 12-03-2001 02:34 PM |
| Price for Greenstuff EBC disc brake pads? | Daffy | Archive Management | 2 | 05-03-2001 04:34 PM |
| I bought PowerSlot disc brake rotors at | 94 RT/10 Black MAMBA | Archive Management | 0 | 12-18-2000 05:54 AM |
