Purchased 08 H Wheels and new OEM sensors for my 04 vert. The tie pressures is 29 PSI X 4, the issue is the LO Press indicator is on? CCW promised if they had my VIN # they could order the correct TPS from Dodge as I sold my OEM ones with my other wheels.Is there a fix as the tires are NOT low?
Site Sponsor / Vendor
we have seen problems like that in the past because many wheels are not designed to accept the sensors correctly and when mounted inside the wheel the signal can't get to the receiver in the car because the valve stem is the antenna and the aftermarket "fix" is to mount the whole sensor/valve assembly inside of the wheel in some form or fashion. How and where are the sensors mounted on the wheel? ... what has CCW said?
For more info on any post or to place an order please call me directly @ 877-522-8473 ext. 362 or use my name for on-line orders |
The TPMS module needs to be programmed for the new sensors. Without your car in hand, no one could have pre-programmed this......... except us
| Another Low Tire/ Tire Pressure Sensor thread... | Blue Batmobile | SRT10 and SRT10 Coupe Discussions | 19 | 09-29-2008 04:16 PM |
| Tire sensor monitor repair | MarkRx | SRT10 and SRT10 Coupe Discussions | 5 | 02-12-2008 11:00 AM |
| Is there a tire pressure sensor in the rim? | Jsparks | SRT10 and SRT10 Coupe Discussions | 5 | 12-18-2007 07:28 PM |
| Low Tire Sensor | Shandon | SRT10 and SRT10 Coupe Discussions | 6 | 02-10-2007 03:30 PM |
| Tire sensor ?? | prevnine11ownr | SRT10 and SRT10 Coupe Discussions | 31 | 03-08-2005 09:22 PM |
