Old 08-25-2008, 03:36 PM   #1
Grant
Default Gen 4 (& 3?) sway bar end link Qs
I'm trying to source some adjustable end links for a gen 4 (I'm assuming the OE links aren't adjustable). Does anyone know the rough dimensions and thread size of the stock links?
Thanks.
I'm looking at Powergrid links (I have a set of theirs for my C5). They should offer the same performance as a heim-jointed end link without all the noise (and with a much longer service life).
Grant is offline   Reply With Quote
Old 08-27-2008, 01:49 AM   #2
j-rho
Default Re: Gen 4 (& 3?) sway bar end link Qs
Hey Grant,
I have my stock swaybar hanging in the garage with its endlinks, so I took a couple measurements. The stock endlinks are 9.5" long overall. The threaded portion is 3/8" diameter, but the shank that goes into the bar conically increases to 1/2". The center-to-center distance for the ball joint pivots is ~6".
Would be interested to see how those links hold up. If you're staying with the stock bar they'll probably be ok. The only endlinks I've ever had to replace due to wear were a set like these, they're OEM on the Infiniti G35 coupe. I prefer the old fashioned heavy-duty teflon-lined units. Not likely that you'll hear rod-end clunking in a Viper anyway.
If you've got a bunch of $ burning a hole in your pocket, I'd recommend the blade-adjustable swaybar available through Dodge Racing. The term "blade adjustable" is heavily misused these days; this piece ($1800) is a true rotating-blade-arm adjustable bar. I had considered getting it for my autox car but it wasn't stiff enough.
A shot of the piece I'm talking about:
Have fun,
j-rho is offline   Reply With Quote
Old 08-27-2008, 10:42 PM   #3
Grant
Originally Posted by j-rho View Post
Hey Grant,
Thanks!
THK (the manufacturer of the ball links) is an OEM, so I'd think the quality would be high. I'd think a greased and booted ball bearing would have to wear more slowly than an exposed spherical bearing. I've only had to replace sealed metal links when the damn allen key strips out.
In any case, I've had some extremely loud heim-jointed links. When greased they just clicked as was normal, but if you ran them for a few days without lubricating them they'd start to squeak very loudly. My car actually sounded like a herd of dump trucks going over speed bumps... Maybe this is abnormal?
This is going on a new ACR, so I'm not really looking to touch the suspension. I think the most I'd do is get some lighter, hollow adjustable bars with around the same stiffness as stock. Though, a in-cockpit adjustable unit would be badass...
Old 09-09-2008, 07:37 PM   #4
Viper X
So Cal VCA President
Wonder what sway bars come as OE on the ACR?
Same as other 2008's? If so, how different are they than the 06's.
How different are they than the comp coupes?
2006 VOI9 Coupe
Sway-bar links or new aftermarket sway-bars? Ray W RT/10 and GTS Discussions 2 11-07-2006 12:17 AM
broken sway bar down link.. 02ViperTodd RT/10 and GTS Discussions 1 04-25-2006 11:59 PM
Adjusting shocks sway bar end link is in the way WTF! Early93Viper RT/10 and GTS Discussions 8 09-26-2005 05:56 PM
Sway Bar dia? V10 ACR RT/10 and GTS Discussions 1 12-02-2004 06:48 PM
Front sway bar Viperoctane RT/10 and GTS Discussions 8 10-21-2002 07:10 AM
