Go Back   Viper Club of America Discussion Forums > VCA Regional Forums > United Kingdom
United Kingdom Forum for United Kingdom Region discussions
Old 04-18-2007, 02:46 PM   #1
ViperDave
UK VCA Member
ViperDave's Avatar
Default Which colour is fastest?
Neil told me to gov
interlinking ?
ViperDave is offline   Reply With Quote
Old 04-18-2007, 03:19 PM   #2
VIPER BAZ UK
UK VCA Member
VIPER BAZ UK's Avatar
Default Re: Which colour is fastest?
Yellow!!!!!!!!!!!!!!!!!!!!
Baz
VCA SAVED TATORS DODGE!!!!!!!!!!!!!
Old 04-20-2007, 03:43 AM   #3
RT/10 Dave
UK VCA Member
RT/10 Dave's Avatar
Red!!!
Ha Ha!!!
Hi guys! (Got my membership card this week)
(Bit quieter over here though...)
RT/10 Dave is offline   Reply With Quote
Old 04-21-2007, 02:33 PM   #4
VIPER BAZ UK
UK VCA Member
Originally Posted by RT/10 Dave View Post
Red!!!
Ha Ha!!!
Not yet its not ................
Baz
Old 04-23-2007, 03:29 PM   #5
VIPER BAZ UK
UK VCA Member
Still not as fast as yellow but its now quick again....................
Baz
Old 05-02-2007, 05:57 AM   #6
RT/10 Dave
UK VCA Member
RT/10 Dave's Avatar
Light travels the same speed through a vacuum at all wavelengths, but when we send the light through something other than a vacuum, like glass we see that light bends/slows, this is seen through snells law below
n1*sin(theta1) = n2*sin(theta2)
The parts of the equation n1 & n2 are called the index of refraction, this is the ratio of the speed of light in a vacuum divided by the speed of light in that substance, so an index of refraction of 1 means that you are in a vacuum, because the speed of light travels the same speed it would in a vacuum. But if you send light through water, water has an index of refraction and light slows down. The process of light slowing down bends the angle at which the direct ray of light travels, so the MORE light slows down the MORE it bends, now say you have a drop of water suspended in a vacuum above your head, white light(which is composed of all frequencies of visible light) hits this clear drop of water and is slowed down and bends, but the different frequencies of light that compose the white light bend different amounts (this amount is small but visible from a distance) the lower frequency light is less affected by the drop of water as it has a longer wavelength and oscillates a lesser amount of times through the distance of the water drop, the higher frequency light oscillates many times through the same water drop and is slowed down more because of it, so it bends more. This process is called diffraction and causes the spectrum of colors in white light to diffract when sent through matter. The blue light(higher frequency) is bent more and the red light is bend less and through this distance of bending is a gradient of light that we call a rainbow.
So, the speed of light is the same for all frequencies in a vacuum BUT when you send light through matter is slows down a certain amount, red light (lower frequency) travels faster than blue light (higher frequency).
The lower frequencies are affected less by traveling through matter, this is why infrared light is used in fiber optics as opposed to ultraviolet or visible light.
Using the Acronym "ROYGBIV", (red, orange, yellow, green, blue, indigo, violet) Those are the colours of the spectrum from lowest frequency to highest frequency, so red light travels faster than all the colours that have a higher frequency than it.
So to sum up....
Red is proven to be fastest...
Help with Viper Colour willis37 General Viper Discussion 3 09-07-2005 04:02 PM
Fastest Wax EVER! TOOOFST RT/10 and GTS Discussions 11 07-28-2005 11:32 AM
SELLING PAINTED VALVE COVER YOU PICK COLOUR Mike Adams New Products, Supplier Specials, and Group Buys 1 09-12-2003 05:36 PM
Colour Compromise with Copper??!! vipernut SRT10 and SRT10 Coupe Discussions 1 12-20-2001 07:46 PM
what colour stripes would look the best on a Black RT/10 GTS Bruce Archive Management 12 05-18-2001 12:37 AM
