Old 05-10-2007, 12:52 PM   #1
pocketAA
Default Trick to get bug guts off of front end
Use a dryer sheet.....I don't know how it does it but it works great!!!
Just wet the dryer sheet with water and begin to wipe where the bugs went splat. After wiping, wash the area and dry it off.....it's like magic...no more bugs.
pocketAA is offline   Reply With Quote
Old 05-10-2007, 03:38 PM   #2
Default Re: Trick to get bug guts off of front end
and make sure to have plenty of wax on it for next time.
NOT affiliated with any tuner...
Old 05-10-2007, 04:24 PM   #3
Johann
An old trick for airplane owners, evidently the dryer sheets contain an enzyme that dissolves bug guts.
Reportedly works as a bug repellent, too; just hang a few dry sheets from your belt loops to keep the critters away.
Johann is offline   Reply With Quote
Old 05-10-2007, 05:01 PM   #4
ViperTony
ViperTony's Avatar
My wife calls it bug jerky...but I found that the Griot's speed shine gets it off pretty easily but the dryer wipes are MUCH cheaper. I think I'll try the mountain scent kind.
- tony
Old 05-11-2007, 11:24 AM   #5
RoadiJeff
Gateway VCA Member
RoadiJeff's Avatar
I've been using the dryer sheet trick for about a year with great results. I think I may have first read about it either on here or in a VCA magazine.
RoadiJeff is offline   Reply With Quote
Old 05-11-2007, 05:12 PM   #6
Steve 00RT/10
Steve 00RT/10's Avatar
I believe Hydrogen Peroxide is the probably the cheapest way to go. I keep some in the car all the time.
Steve
Old 05-12-2007, 12:53 AM   #7
RoadiJeff
Gateway VCA Member
RoadiJeff's Avatar
I heard about the Hydrogen Peroxide trick, too. I was reluctant to use that since I wasn't sure the boiling effect was safe for the finish.
Obviously, you have used it. Can you confirm that it doesn't leave any mark on the finish that can't easily be wiped off with a little detail spray and a MF cloth?
Old 05-12-2007, 10:10 AM   #8
Steve 00RT/10
It has never left a mark or caused me any concern. I don't know for a fact, but I wonder if some of the liquid products available have HPo2 in them as the bug dissolving agent? If so, that would be a very healthy profit margin for them.
I have used other products prior to this and they reacted exactly the same way.......the critter instantly turns white and does a little bubblin'
Steve
Old 05-15-2007, 07:19 AM   #9
agentf1
WV/PA VCA Member
agentf1's Avatar
I keep my bumper Zaino'd real good so any buds just wipe right off with soap (Z7) and water really easy.
On cars that I detail that do not have a good coat of protection I soak them with soap and water and then use a micro fiber applicator to scrub them off. The applicator is called the power scrubber and is from properautocare.com and work real well with no scratching at all. Those mesh like bug removers work well also.
An ounce of prevention is worth a pound of cure. I will usually remove them right away with a wet sponge and then dry the bumper as the longer they are on there the harder they get to remove. Bug guts are also very acidic and will eventually etch your paint if left on the bumper long enough.
Tators Rocks.
Old 05-15-2007, 07:51 AM   #10
GTSnake
GTSnake's Avatar
Does the dryer sheet have to be new or can it be used?
How about Hydrogen peroxide and wiping with the dryer sheet?
'97 GTS
1304 RWHP CPE TT system
updated life insurance...
Old 05-15-2007, 09:32 AM   #11
Janni
Carolinas VCA Member
Janni's Avatar
I am thinking that is you can pour hydrogen peroxide on a cut in human flesh, your paint ought to be able to handle it.
Thanks for the dryer sheet tip - I'll be checking that out!!!!
Janni Cone
Carolinas Region Member
Janni is offline   Reply With Quote
Old 05-15-2007, 10:06 AM   #12
Steve 00RT/10
I carry both Hydrogen Peroxide and the dryer sheets. I also used the dryer sheets last winter for storage -- placed in several places in/on the car.
Steve
Old 05-15-2007, 10:32 AM   #13
Bolt
Bolt's Avatar
I use WD-40.
Works great for tar too.
Bolt
Bolt
Bolt is offline   Reply With Quote
Old 05-15-2007, 12:07 PM   #14
pocketAA
New dryer sheet works, you need whatever white film is in the dryer sheet to wipe off the bugs. After using the dryer sheet, be sure to wash the front with soap and water.
Old 05-15-2007, 05:40 PM   #15
mad0953
Oregon VCA Member
mad0953's Avatar
agentf1...................can I have some of those "buds" you wiped off of the front of your car??
A few pics of some yellow guts !! GCHDEALER RT/10 and GTS Discussions 15 01-09-2004 02:45 PM
What do you use to get a b'zillion bug guts off the front end of your Viper ?? JH23JOB Sneaky Pete's Place 9 07-16-2002 10:45 PM
What's the trick? Lee Dove Archive Management 3 06-04-2001 09:35 PM
Hot to remove bug guts? Matt Archive Management 7 04-12-2001 12:22 PM
