1997 GTS, Vortech SC, Intercooled, 726 RWHP 1974 Dodge Charger 542 Hemi / 1963 Ford Falcon Fire Chief |
#17 | |
1994 RT/10 |
PROPSAIL, You would need to follow the Illustrated and get it down below the oxidation before you can keep it up with just a light polishing.
2000 GTS, Roe 5lbs, RR, VEC3, JMB Performance intakes, Dual .50 cals, Corsa Cat Back, Innovate LC-1 WB Last edited by DAMN YANKEE; 01-12-2008 at 07:02 AM. |
Theres some great suggestions already in this thread, but I typically use either clearkotes metal polish or megs billet alum polish for any metal work. You can also try some wd40 when the area is still hot
#20 | |
Actually, with the forecast today for sunny and 65, we're taking the GTS to Car Toys to discuss "options." Screw yard work. |
#21 |
Dave,
Nah, Saturday is your book signing in Lubbock.....
2000 GTS, Roe 5lbs, RR, VEC3, JMB Performance intakes, Dual .50 cals, Corsa Cat Back, Innovate LC-1 WB |
#22 |
2000 grit was a great tip. I did that with a sanding block and I used high heat clear with a q-tip to put a coat of protection on.
#23 |
It worked great on mine. I guess my valve cover text was not in bad shape.
1994 Viper RT/10 Tatorized |
#24 |
Like Newport Viper I buffed them out using 800 to 1000 to 1500 to 2000 grit sandpaper and a sanding block. I taped the painted part as best I could using blue painters tape. After sanding I applied a couple coats of Klasse All-In-One. They look better then like new.
| Valve Cover Bolts | SYNFULL | RT/10 and GTS Discussions | 6 | 01-05-2007 07:24 PM |
| Are new valve cover gaskets really necessary? | trainville | RT/10 and GTS Discussions | 2 | 11-03-2006 06:32 PM |
| Another Valve Cover Question | DrumrBoy | RT/10 and GTS Discussions | 3 | 05-01-2006 04:10 AM |
| valve cover colors | grandrt | SRT10 and SRT10 Coupe Discussions | 0 | 11-30-2004 11:14 AM |
| Where does oil ON valve cover come from? | Black 94 | RT/10 and GTS Discussions | 5 | 10-25-2004 05:50 PM |
