Old 10-19-2007, 11:13 PM   #1
okloneranger
Oklahoma VCA Member
okloneranger's Avatar
Default under-hood heatshield cleanup?
Does anyone even try to cleanup or detail the heatshield blanket under the hood? I'm not too sure of what it's made of or if there is even a way to clean it and or blacken it back to like new condition. Also, what would you use to recolor rub spots on the fiberglass rubbing against weatherstripping?
okloneranger is offline   Reply With Quote
Old 10-20-2007, 02:10 AM   #2
DEADEYE
Default Re: under-hood heatshield cleanup?
Some people remove it and spray paint it black. I would do that if I knew how to remove it. Those tabs look fragile.
DEADEYE is offline   Reply With Quote
Old 10-20-2007, 09:01 AM   #3
ViperTony
ViperTony's Avatar
I removed my pad and painted the sneaky pete logo on it. I then finished it by spraying 2-3 coats of clear on it to help make cleanup easier. There are a few how-to's on painting/removing hood pads. Try searching on "paint hoodpad" or "remove hoodpad" I found several good hits. The retaining clips will need to be replaced as they break off easily. You can use plastic pry-bar tools to remove the clips at your local AutoZone. A good pair of pliars also does the job nicely. I found replacement clips at my local hardware store.
WE SAVED TATOR'S DODGE
Old 11-18-2007, 10:28 PM   #4
Edward 96GTS
I had the white film on the pad. It seems to form after the pad gets wet from car washing. I used Mequires Vinyl/Rubber Protectant. Removed the whitish film, now pad looks brand new. I just saturated a towel and dabbed it all over the pad. Do not rub pad as it may cause it to fray. Do a test sample in the corner of the pad to get comfortable.
ed
Edward 96GTS is offline   Reply With Quote
Old 11-19-2007, 09:44 AM   #5
Nader
NY VCA Member
Nader's Avatar
I noticed something interesting in the service manual i purchased. For an 04, the pad is called a noise silencer. Therefore i dont think it is specifically used to address the heat and protect the hood, at least for 03 plus.
Garage cleanup/ parts for sale riverflyer RT/10 and GTS Discussions 7 07-25-2004 11:34 PM
Sidesill heatshield glue? Andy RT/10 and GTS Discussions 4 05-26-2003 08:34 PM
Baby Wipes Perfect for Bug Cleanup Tom and Vipers RT/10 and GTS Discussions 6 09-03-2001 11:20 PM
Dodge has offered to replace my hood with a 1996 hood. What kind of 94 RT/10 Black MAMBA Archive Management 5 10-27-2000 11:44 PM
