Old 11-13-2007, 07:10 PM   #1
Gus Strakes
VA/MD VCA Treasurer
Gus Strakes's Avatar
Default Zaino shelf life.
I have a bottle of Z1 and a bottle of Z2 never opened that has been sitting on a shelf in my garage and are at least 4 years old. Is it still Ok to use, or will I be wasting my time?
Regards,
Gus (in Maryland)
06 SRT-10 VOI9 #75
02 GTS FE #022
Gus Strakes is offline   Reply With Quote
Old 11-13-2007, 08:46 PM   #2
Dan
Default Re: Zaino shelf life.
Usually Id say as long as it hasn't froze, it should be fine. But 4 years is a pretty long time. Im going to guess that it might be alright to use, but Id call Zaino, dont take my word for it.
Dan is offline   Reply With Quote
Old 11-13-2007, 08:58 PM   #3
carguy07
carguy07's Avatar
From their site:
Q: What is the usable shelf life of Zaino products?
A: A 70° room temperature is best for the longevity of Zaino products. Due to the optical additives used, extreme heat or cold can result in a decrease in gloss-enhancing properties.
When stored at average room temperature between 65° and 75° degrees, shelf life is as follows:
Z-PC 3+ years
Z-AIO 3+ years
Z-CS 5+ years
Z-1 For optimum results, use before 3 years.
Z-2 For optimum results, use before 3 years.
Z-3 For optimum results, use before 3 years.
Z-5 For optimum results, use before 3 years.
Z-6 5+ years
Z-7 5+ years
Z-8 5+ years
Z-9 5+ years
Z-10 For optimum results, use before 2 years.
Z-12 For optimum results, use before 2 years.
Z-14 For optimum results, use before 2 years.
Z-16 3 to 5 years
Z-18 5 years +
ZFX For optimum results, keep tightly capped, avoiding moisture. Use before 24 months.
I have gotten away with close to 4 years with the polish and been fine. ZFX on the other hand is long gone before 24 months.
carguy07 is offline   Reply With Quote
Old 11-14-2007, 09:00 AM   #4
agentf1
WV/PA VCA Member
agentf1's Avatar
It is probably fine but I would pick up some of the new and improved Z2 Pro and some ZFX instead. Zaino has really improved their product over the years. It is much easier to use now and dries faster and even has a better look.
Z1 is also a thing of the past and not even sold anymore. Now you can either mix in a few drops of ZFX in a little mixing bottle to your Z2p or Z5p or you can use their new Z-AIO (All in one) cleaner polish first which eliminates the need for ZFX.
Note: ZFX is still needed if applying more than 1 coat at a time within a 24 hour period.
Old 11-17-2007, 02:05 PM   #5
it doesnt work well when freshly made, id toss and buy a good product.
plumcrazy is online now   Reply With Quote
Mobil 1 shelf life Mopar488 RT/10 and GTS Discussions 5 07-01-2007 08:32 PM
Mobile One shelf life SuperSaiks RT/10 and GTS Discussions 13 11-29-2006 03:55 PM
Shelf life of Hoosiers???? PhilC RT/10 and GTS Discussions 12 12-17-2003 08:40 AM
Shelf Life of Silicone Brake Fluid? Matt M, PA RT/10 and GTS Discussions 1 11-12-2002 12:28 PM
Shelf Life on regular motor oil? onerareviper Sneaky Pete's Place 5 04-05-2002 04:42 AM
