lacquer thinner will work fine.
96 Blue/White GTS 96 Blue/White Indy Ram Ride Fast Or Be Last |
Paint thinner as previously mentioned, or even a good swirl removal product and a D/A buffer will do it for removing light overspray.
'98 Viper RT/10 JMB intake, B&M, hi-flow cats, Borla, SCT tune, 18/19 IForged/PS2's '96 Caprice 9C1 '02 Z06 562rwhp/467ft-lbs**SOLD** |
#18 | |
1993 RT/10 "Blown and Bottle fed" |
I bought the mothers clay bar kit, comes with the clay, showtime spray, and carnauba wax.
I will "wax on, wax off" Sat. and let everyone know how it goes. So when doing the clay, do you guys recommend breaking chunks off a little at a time then? |
#20 |
YES.
I usually break mine in half. Put one half in a ziplock back, and then use the other half. You might use both, but regardless - if you drop one of the halves - THROW IT OUT, and start with the new one. If your car has never seen a clar bar, I would suggest on planning to use both halves. As it gets a little dirty, roll it back into a ball and flatten out a fresh surface. You need to be the judge on when it gets to dirty - a little isn't bad...but at least plan on doing this for each body panel ( maybe more) until you know when is time. -Quick Spray is your friend, don't be afraid to use a lot of it. -NEVER, EVER use dropped clay -Wipe up your detail spray as you move along with a nice microfiber cloth -Polish/Wax when you're done! |
#21 |
Definitely clay bar. I prefer a good QD as my lube and just make sure you keep kneading the clay and using a fresh surface often. Do a small panel and then roll clay in ball and mix up and then re flatten like a pancake and do next section. Plenty of QD as a lube. DO NOT rub hard as it is not required for the clay bar to work properly, it should lightly glide across finish. If you drop it get a new one.
Do baggie test to verify all contaminants have been removed.
2001 Sapphire/Silver GTS - Random Tech High Flow Cats and Corsa's Tators Rocks. |
#22 |
What is the baggie test?
I did the clay bar today, it all came off. but the one area with the most over spray took a few times to get it all off. That showtime spray is really nice, it does not streak or anything. very smooth afterward. Thanks for the recommendation guys. |
#23 |
Glad it all came off for you. The baggie test: Take a piece of plastic wrap or a baggie and slide it over the paint. If it drags or catches on the paint there are still contaminants left behind. It should glide smoothly.
'06 First Edition 194/200
| My mistake... | DAMN YANKEE | Board and Site Questions/Suggestions | 1 | 05-13-2007 09:06 PM |
| Dumb Question but Mom said there are No Dumb Questions | HARDVIPER | RT/10 and GTS Discussions | 12 | 04-16-2006 09:28 AM |
| mistake | BIRD | SRT10 and SRT10 Coupe Discussions | 19 | 01-24-2004 02:26 PM |
| SRT-10 Truck a mistake? | SapphireGTS | SRT10 and SRT10 Coupe Discussions | 24 | 01-18-2002 11:37 PM |
| Die Cast mistake | Joseph Houss | Merchandise, Collectibles, Memorabilia, Apparel, and Miniatures | 8 | 01-14-2001 07:18 PM |
