Old 04-06-2008, 05:09 PM   #1
Pryme
Default Dumb mistake, please help.
So I was using black spray pain about 15-20 feet from my car, and when I was washing it today I noticed some how a little dusting went on part of the hood, only a small area and because the car is black, it is hard to see but you can see it up close and feel it.
So how do I remove it?
Will a nice buffing take care of it or what about a lil diluted paint thinner, the cars clear coat should be OK I would think, but I would like some advice from you all.
Thanks.
Pryme is offline   Reply With Quote
Old 04-06-2008, 05:16 PM   #2
Nader
NY VCA Member
Nader's Avatar
Default Re: Dumb mistake, please help.
clay bar will do it.
Old 04-06-2008, 05:19 PM   #3
Bravo
clay bar +1
Bravo is offline   Reply With Quote
Old 04-06-2008, 05:41 PM   #4
ViperTony
ViperTony's Avatar
This happened to me when I was painting my hoodpad across the garage. I ended up using Giot's speed shine and their claybar to clean up the paint. Followed it up with a fresh coat of wax.
WE SAVED TATOR'S DODGE
Old 04-06-2008, 06:04 PM   #5
Pryme
I have never used clay bar, is it pretty easy? what do I need? just the clay bar, any advice would be appreciated. Thanks.
Old 04-06-2008, 06:08 PM   #6
RedEnuf93
PA/WV VCA Member
RedEnuf93's Avatar
Buy Mothers clay bar and detail mist. (or any other brand at local Advance Auto, Pep Boys, Autozone etc...)
Mist surface and move clay across paint. Dry off with clean towel. Continue until paint feels slick and smooth. NEVER clay dry, always mist generously...
IF you ever drop clay on ground, NEVER use it again. Nothing like sand grinding against your paint...
VERY EASY...
1993 RT/10
"Blown and Bottle fed"
SAVE TATORS DODGE!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 04-06-2008, 06:08 PM   #7
ViperTony
ViperTony's Avatar
I think Griot's detailers handbook has great info on the Claybar technique. See here, page 32.
Old 04-06-2008, 06:45 PM   #8
Pryme
WOW that does sound easy, I will have to give it a try. What else does clay do for the paint, I should try that with my other car, my Daily driver, the paint needs some tlc.
Old 04-06-2008, 08:44 PM   #9
TAXIMAN1
NJ VCA Member
TAXIMAN1's Avatar
either clay bar, or maguiars makes a "paint cleaner". Just use that, with a micro fiber towel. It will come off.. Spray does not usually stick "really well" to much of anything.. It should come right off.
TAXIMAN1 is offline   Reply With Quote
Old 04-06-2008, 09:32 PM   #10
Newport Viper
Newport Viper's Avatar
good info here for all.
Car Care Forums: Meguiar's Online - Powered by vBulletin
1995 Viper (sold)
2004 Silver Viper
Old 04-07-2008, 04:25 AM   #11
Lone Star beer poured on your girlfriend's cat will buff that right out.
Old 04-07-2008, 05:48 AM   #12
ryan94rt10
Ohio VCA Member
ryan94rt10's Avatar
a little paint reducer should take it off too...i get mine at napa!
Ryan
________________________________________________
1994 Red RT/10
K&N high flow filters w/Corsa cat-back exhaust
MGW short throw shifter & dash accesseries
18' GTS chromes w/Pilots
ryan94rt10 is offline   Reply With Quote
Old 04-08-2008, 06:37 PM   #13
IEATVETS
Illinois VCA Member
IEATVETS's Avatar
I want to clay bar my car but I am really nervous in doing so. I cannot understand how using a clay bar on your car does not scratch the paint. Sure, you use cleaner to lubricate the clay bar as you go across the paint but I saw a picture in Griot's latest magazine and it shows the dirt and contaminents on the clay bar! I would think that by dragging those contaminents back and forth on the paint, that it would scratch the hell out of it!
If you guys swear by clay bars, then I will try it, with slight hesitation.
2000 GTS
Steel grey/Silver stripes
1 of 126
Old 04-08-2008, 07:24 PM   #14
PittsburghRT
PA/WV VCA Member
PittsburghRT's Avatar
Keep the paint surface wet with the provided detailer in the area you are sliding the clay bar over and you should be fine. Also, every so often replace the piece of clay if you notice it is picking up a lot of contaminants. I state this because I never use the whole bar from the kit all at one time. I do this every year to my everyday car that is black and it works well.
1994 Viper RT/10
Tatorized
PittsburghRT is online now   Reply With Quote
Old 04-08-2008, 08:05 PM   #15
ViperTony
ViperTony's Avatar
I've done the claybar routine on all of my cars and just did my Viper again. I use the Griot's kit: Speed Shine and Clay bar. The Speed Shine is slippery. Keep the surface you're working on wet with the speed shine. Rip off a piece of the clay, flatten it out and began going over the area. As the clay gets dirty, rework it and keep going. If I drop the clay I usually toss that piece out and rip off a fresh piece. It only take a few strokes. You may need several strokes to get the over spray off but it does work...don't be afraid.
My mistake... DAMN YANKEE Board and Site Questions/Suggestions 1 05-13-2007 09:06 PM
Dumb Question but Mom said there are No Dumb Questions HARDVIPER RT/10 and GTS Discussions 12 04-16-2006 09:28 AM
mistake BIRD SRT10 and SRT10 Coupe Discussions 19 01-24-2004 02:26 PM
SRT-10 Truck a mistake? SapphireGTS SRT10 and SRT10 Coupe Discussions 24 01-18-2002 11:37 PM
Die Cast mistake Joseph Houss Merchandise, Collectibles, Memorabilia, Apparel, and Miniatures 8 01-14-2001 07:18 PM
