Old 04-13-2008, 05:05 PM   #1
Obsidian
New Jersey VCA member
Obsidian's Avatar
Default Removing Swirls
While I recognize this topic has been discussed a few times, I want to ask it again since I want to consider a few options. How do I remove swirls from my Viper (I have sapphire blue):
1. Can it be done without power tools?
2. Can it be put in the hands of a detailer?
3. If power tools are the way to go, what is the best tools and products to use?
Thanks!
Obsidian is offline   Reply With Quote
Old 04-13-2008, 05:33 PM   #2
Default Re: Removing Swirls
cant really be done without power tools but id ask it in the detailing section maybe for more help
NOT affiliated with any tuner...
Old 04-13-2008, 06:55 PM   #3
jojogts
I have a black silver stripes gts. Had the same problem I use 3m products swirl remover then 3M fine swirl remover bar none the best I have ever used or seen. Use a variable speed buffer with the correct foam pads you will be very happy.
jojogts is offline   Reply With Quote
Old 04-13-2008, 10:35 PM   #4
Newport Viper
Newport Viper's Avatar
much info here search swirls and viper
Car Care Forums: Meguiar's Online - Powered by vBulletin
1995 Viper (sold)
2004 Silver Viper
Newport Viper is online now   Reply With Quote
Old 04-14-2008, 09:18 AM   #5
RobZilla
Florida VCA Member
RobZilla's Avatar
There are several topic around the forum on this topic. Do a search. I know there is one titles "For those with black cars"
The best tool around is the Porter Cable 7924 buffer.
'00 Black RT/10 - - B&B Headers, Cat Delete, Corsa CatBack Exhaust, '06 Tranny, K&N,
Smooth Tubes, Poly Mounts, Vec II, HID's, Short Throw Shifter, Chromoly Flywheel
Old 04-14-2008, 10:18 AM   #6
RoadiJeff
Gateway VCA Member
RoadiJeff's Avatar
Umm...Porter Cable 7424
RoadiJeff is offline   Reply With Quote
Best way to get Swirls out Inferno RT/10 and GTS Discussions 91 11-28-2005 03:35 PM
Filling Chips and Removing Swirls and Small Scratches TCKTPLZ General Viper Discussion 18 05-19-2005 12:36 AM
How Do I Get Rid Of The Swirls On My Car? DodgeViper01 RT/10 and GTS Discussions 29 10-16-2004 11:53 PM
Need help removing wax Diablo Joe RT/10 and GTS Discussions 13 05-13-2002 11:33 PM
Removing AC Nadine UK GTS RT/10 and GTS Discussions 12 02-10-2002 08:10 PM
