Old 04-29-2008, 07:06 PM   #1
bdherh
Default Rock chips
I have a couple of small rock chips on my front facia. Nothing big but I know they are there, so I want to get them fixed. What is the best way to get those fixed? Touch up paint is hard to smooth over. Any suggestions?
bdherh is offline   Reply With Quote
Old 04-30-2008, 06:54 AM   #2
texas_venom
Default Re: Rock chips
When you do get them fixed I highly recommend getting a ClearMask put on. It will prevent you from having to worry about any more in the future.
texas_venom is offline   Reply With Quote
Old 05-16-2008, 01:33 PM   #3
00prowler
I use a sharpie close to the color of my car...works pretty good...Al
00prowler is offline   Reply With Quote
Old 05-16-2008, 01:36 PM   #4
ViperTony
ViperTony's Avatar
I've had good results with the paint pens from PaintScratch.com. Langka makes a kit that allows you to smooth out the touch-up paint. It works pretty well.
WE SAVED TATOR'S DODGE
Old 05-16-2008, 02:59 PM   #5
PaViper
PaViper's Avatar
Langka works better than anything else I have tried
06 VCA Coupe #38
02 FE GTS #173 (Sold)
Old 05-16-2008, 03:00 PM   #6
PaViper
PaViper's Avatar
LANGKA Paint Chip and Scratch Repair
try it you will like it
06 VCA Coupe #38
Old 05-16-2008, 03:02 PM   #7
VIPER GTSR 91
VIPER GTSR 91's Avatar
+1 and well said. Its easy and I use it on all the cars. Order it on line.
HOUSTON VCA MEMBER
VIPER GTSR 91 is offline   Reply With Quote
Old 05-18-2008, 07:38 PM   #8
tcslc
Guest
Posts: n/a
I'm not familiar with the kit referenced earlier, but basically what you want to do is remove any loose paint from the chip, fill it in high, and sand it smooth with progressively fine paper. It'll take some guts to put sandpaper on your baby, but you are wetsanding with very fine grit paper (up to 1500 grit at the end) to remove and smooth out the high spot where you filled in, and then following with polish and finally wax. The repair should be completely unnoticeable when you are finished. Look up color sanding on the web, and you'll find a lot of info. Good luck!
Old 05-18-2008, 07:44 PM   #9
ViperTony
ViperTony's Avatar
The langka kit is so easy even I could do it. The Langka kit is for removing paint blobs from chip repairs. No sanding. It requires rubbing the blob with their paint smoother until its flat. Same with the clear coat sealer it comes with. I just found another dime-sized chip. I'll try to take pics of the before, during and after sometime this week.
Rock Chips John Abbate SRT10 and SRT10 Coupe Discussions 9 04-16-2007 09:23 AM
Rock chips.... SRTRICKY SRT10 and SRT10 Coupe Discussions 12 04-13-2007 03:53 PM
Paint chips? Mopar-man SRT10 and SRT10 Coupe Discussions 4 10-28-2006 05:00 PM
Rock chips and sill covering.................. 1TONY1 SRT10 and SRT10 Coupe Discussions 0 11-17-2003 11:28 AM
Anyone have the clear tape which goes on the side sills for rock chips? Sniper RT/10 and GTS Discussions 10 03-16-2003 05:00 PM
