| Viper Racing/Dyno Results/Time Slips Discussion about GT2, American LeMans, Viper Days racing series, or post your race results, dyno printouts and timeslips here. Sponsored by: DragTimes.com |
I took my 01 GTS to a local Dynojet Dyno today (opened 1 week ago). Mine was the first Viper they had tested. This was also the cars first test, as well as my first dyno experience. I made the following runs:
378 HP 450 LBFT 422 HP 475 LBFT 445 HP 482 LBFT 84 DEG, HUMIDITY 47% These runs were made about 3-5 minutes apart. I thought these were good numbers based on the 450 HP and about 475 LBFT flywheel stock numbers. But upon further review, I have seen other with less mods that are reporting numbers very close to this. I ran short on time so I didn't do any more than the 3 pulls. Should I have done more than 3 pulls? Did I wait too long or not long enough between pulls? I am hoping that I had more in it, but I want some advice before I go back for more. I am trying to get the dyno printouts e-mailed to me so I can get them posted. |
Actually be glad you got at least one good pull at 445hp 482lbft. I would think that pull was pretty normal with those mods. I think the cast piston cars do not get as much HP out of headers and exhaust as the forged piston cars. You may want to call Sean Roe and ask about a Vec 1 or Vec 2. For the money it gives a nice little extra hp approx. 15hp to wheels. What headers do you have?
B&B headers.
I hear those are good headers. I guess some of the other 01's need to chime in to give you something to compare with. But I think your fine with those last numbers.
I haven't dyno'd with my current mods, but those numbers sound fairly reasonable to me. I dynoed 432hp/469tq with catback and smooth tubes and hope to break 450 with my current mods. I'd think you'd be somewhere in the 440 - 460 range with your mods as well.
From the way your numbers were jumping up, it looks like your car was doing some learning and a 4th run may have bumped up again. You might try doing some WOT runs before you hit the dyno next time, so the car knows what is expected of it. I assume your numbers are SAE corrected. If not, then that would also raise your numbers a little as well since it was a fairly warm day. |
I have the same mods, with vec1 and I made 454/489.
Thanks for the info. I will post again after next dyno.
Go to a different dyno.
No viper with your mods will pull number so radically far apart from each other. The operator has no idea on how to operate or calibrate the settings, or there is something wrong with the actual equipment. If it is a mustang dyno, then it is the fault of the manufacturer. |
Mustang dynos are the best dynos out there and the most expensive.
vd.. |
How can you trust a dyno that gives you such a huge range of HP (378-445 RWHP)between runs? There's over a 60 RWHP difference between first and last runs.
These #'s seem low if I'm reading your mods correctly. It says you have a Roe supercharger.
Added the Roe after Dyno. I was told that unless you run WOT often or atleast prior to running on the Dyno, the nubmers would be closer. I heard this from the guys running the Dyno and a Viper Tuner.
Excuse my poor grammar and sentence structure. What I meant to say was that unless you are running WOT often or at least prior to running on the dyno, the numbers would vary quite a bit as the computer is "learning".
| Actual Dyno of Paolo Castellano's 1512 RWHP Dyno!! | JGK95 | RT/10 and GTS Discussions | 23 | 04-21-2005 12:48 PM |
| Viper dyno day in NY | VIPER D | RT/10 and GTS Discussions | 14 | 07-30-2004 10:07 PM |
| Viper dyno day in NY | VIPER D | SRT10 and SRT10 Coupe Discussions | 22 | 07-30-2004 07:54 PM |
| Only 1 Dyno spot left...Register Now! APEX Motorsports Dyno Day & Parts Showcase | LTHL VPR | RT/10 and GTS Discussions | 2 | 09-15-2001 02:25 PM |
| What is your best dyno on your viper | BlackACR | RT/10 and GTS Discussions | 5 | 09-06-2001 07:50 PM |
